Date/Time: Tue, 14 Jan 2025 12:52:05 +0000
Create an alert if RSI cross from below
View Count: 2125
[2017-05-15 16:41:42] |
User1193154 - Posts: 54 |
Hello, I like to write a condition in RSI alert sound: CROSSFROMBELOW (SG1,51) Is'it correct? Thank you for helping Flavia |
[2017-05-16 05:13:48] |
Yes, that is a correct formula.
[2017-05-17 16:30:58] |
Ty very much Regards, Flavia |
