Date/Time: Tue, 14 Jan 2025 11:50:58 +0000
Export the data
View Count: 643
[2017-05-15 14:49:28] |
Deltareversal - Posts: 46 |
Hi, please inform how can I do to export the data to a txt file, such as the attached one. Exemple: -Ticker Date Time Open High Low Last Volume Open Interest @ES# 2010-10-21T16:00 1016.00 1017.75 1013.25 1017.50 205584 0 @ES# 2010-10-21T17:00 1017.25 1022.25 1014.50 1021.75 407851 0 @ES# 2010-10-21T18:00 1021.75 1022.25 1012.00 1015.75 360837 0 @ES# 2010-10-21T19:00 1015.75 1016.25 1010.75 1012.25 237064 0 @ES# 2010-10-21T20:00 1012.25 1014.75 1003.75 1004.75 275200 0 @ES# 2010-10-21T21:00 1004.75 1010.00 1003.25 1009.25 264603 0 @ES# 2010-10-21T22:00 1009.25 1013.50 1008.25 1012.50 288202 0 |
@ES#_60 Minutes.txt - Attached On 2017-05-15 14:47:22 UTC - Size: 2.1 MB - 297 views |
[2017-05-15 15:01:05] |
There are various commands for exporting data on the Edit menu. They are all documented on this page: http://www.sierrachart.com/index.php?page=doc/EditMenu.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
