Date/Time: Tue, 14 Jan 2025 11:38:19 +0000
Terrible Trial
View Count: 768
[2017-05-14 23:41:11] |
User138418 - Posts: 16 |
Spent most of the day trying to get SOMETHING to happen, and it aint happened yet. Reading Internal Order ID file. | 2017-05-14 16:01:20 Reading Trade Orders file. | 2017-05-14 16:01:20 Reading Trade Positions file. | 2017-05-14 16:01:20 Listening on UDP port 22903. | 2017-05-14 16:01:20 Software version: 1556 | 2017-05-14 16:01:20 Uses New Spreadsheets | 2017-05-14 16:01:20 Usage end date: 2017-05-28 | 2017-05-14 16:01:20 Enabled for: Advanced Features. | 2017-05-14 16:01:20 Enabled for: Advanced Features 2. | 2017-05-14 16:01:20 Enabled for: Sierra Chart Historical Data Service. | 2017-05-14 16:01:20 Allow Support for Sierra Chart Data Feeds is enabled. | 2017-05-14 16:01:20 Current selected Data/Trading service: SC Data - All Services | 2017-05-14 16:01:20 Chart Update Interval: 500 | 2017-05-14 16:01:20 Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-05-14 16:01:20 2017-05-14 16:01:23 Local computer time | 2017-05-14 16:01:20 2017-05-14 23:01:23 Local computer time in UTC | 2017-05-14 16:01:20 2017-05-14 16:01:23 Local computer time in SC Time Zone | 2017-05-14 16:01:20 2017-05-14 23:01:24 Server time in UTC | 2017-05-14 16:01:20 Local computer UTC time and Server UTC time difference: 1 seconds. | 2017-05-14 16:01:20 Program path: C:\SierraChart\ | 2017-05-14 16:01:20 Data Files path: C:\SierraChart\Data\ | 2017-05-14 16:01:20 OS Version Number: 6.2 | 2017-05-14 16:01:20 Locale Setting: C | 2017-05-14 16:01:20 Checking for new symbol settings for service code scdataallservices | 2017-05-14 16:01:20 HTTPS connection to www.sierrachart.com:443 (3) | Creating socket. Using TLS 1.2. | 2017-05-14 16:01:20 HTTPS connection to www.sierrachart.com:443 (3) | Connecting to IP: 5.9.8.236. | 2017-05-14 16:01:20 Symbol settings are up-to-date for scdataallservices | 2017-05-14 16:01:28 SC Data - All Services | Connected to data server. | 2017-05-14 16:01:28 HTTPS connection to www.sierrachart.com:443 (3) | Socket gracefully closed by remote side. | 2017-05-14 16:01:33 HTTPS connection to www.sierrachart.com:443 (3) | Received socket Close event | 2017-05-14 16:01:33 HTTPS connection to www.sierrachart.com:443 (3) | Initiating close of socket by core. | 2017-05-14 16:01:33 HTTPS connection to www.sierrachart.com:443 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-05-14 16:01:33 HTTPS connection to www.sierrachart.com:443 (3) | Closed. | 2017-05-14 16:01:33 why is the remote side gracefully closing stuff? HOW DO I GET THIS THING TO SOW ME SOMETHING? ANYTHING!?! |
[2017-05-15 02:00:32] |
You really should go through the Getting Started instructions here: Getting Started, Opening Charts and Basic Trading You need to open a chart through File >> Find Symbol. We recommend the Forex symbol EURUSD. Real-time data in the trial is provided for Forex and CFD symbols. Refer to this page: Sierra Chart Real Time and Historical Forex and CFD Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
