Date/Time: Tue, 14 Jan 2025 11:37:26 +0000
Placing Horizontal Line erases Cross-Hairs
View Count: 697
[2017-05-14 23:34:36]
User94740 - Posts: 333
could you please tell me if it is correct that my cross-hairs are taken away every time I place a horizontal line? This means: I right click to the shortcut and click on horizontal line and every chart where I had my cross hairs pointer is gone.
[2017-05-15 00:16:27]
Merlin - Posts: 83
Try setting this option from the main menu:
Tools/Tool Settings/General, "After Single Tool Use Change To", select "Chart Values" instead of "None".
I also have shortcut keys set for "Pointer", "Chart Values/Crosshair", and "Hand", so I can easily switch between them.
Date Time Of Last Edit: 2017-05-15 00:17:19
[2017-05-15 02:11:04]
Yes what you describe does make sense.
You can keep the Chart Values Tool always active. Refer to the options here for this:
https://www.sierrachart.com/index.php?page=doc/Tools.html#ChartValuesToolSettings
Date Time Of Last Edit: 2017-05-15 02:11:22
[2017-05-15 11:59:04]
thank u Merlin and I had made this setting to "chart values" a long time ago and is still the setting. I will have to take a look at the suggestion from sc.
