Date/Time: Tue, 14 Jan 2025 11:39:33 +0000
Yearly VWAP different values on historical and intraday charts
View Count: 1875
[2017-05-14 12:43:25]
User995923 - Posts: 64
Hello
I am using the yearly VWAP indicator on a daily chart of the currency futures 6E (EUR/USD) (Continuous Date Rule Rollover, Back-adjusted).
Up until now the chart data type was intraday.
However due to performance issues I have been playing around with historical charts and I realised that the value of VWAP is different when I change the chart type from Intraday to Historical.
So is there any problem? And if not which one is the correct one? If it is the intraday setting, can I apply it on a historical chart in order to make Sierra Chart more performance-efficient?
VWAP Settings
Input Data: Last
Based on Underlying Data: Yes
Time Period 1 Year
Start Date: 00:00:00
STD Band Calculation Method: VWAP Variance
Regards
Andreas
[2017-05-14 17:22:18]
The Volume Weighted Average Price study on a Historical Daily chart will be less precise.
If you find that acceptable, there is no problem doing that.
Date Time Of Last Edit: 2017-05-14 17:22:35
