Date/Time: Tue, 14 Jan 2025 11:50:50 +0000
charting bond futures butterfly
View Count: 1428
[2017-05-13 17:36:34] |
User158215 - Posts: 2 |
Hi I would like chart several bond future butterflies. an example would be --/zn-(/zf*.83)-(/zb*.17). Could you tell me where I could find this instruction?
[2017-05-15 02:15:30] |
This can be done. Use the Spread-Butterfly study. Refer to: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=259#Spread_-_Butterfly If you wanted an exchange traded spread, that is supported as well. Let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-15 18:05:25] |
infpz - Posts: 826 |
Assuming this inquiry is the result of our recent webinar, please contact me directly and I'll get you a premade file. pz@infinityfutures.com
