Date/Time: Tue, 14 Jan 2025 11:26:47 +0000
Minor bug with copying chart drawings between charts and the text tool.
View Count: 775
[2017-05-13 01:09:00]
User62936 - Posts: 68
I just discovered a minor bug with copying specifically text between chart drawings. Please refer to the attachments.
On the left chart is the original text that is automatically copied to the right chart. When the text is updated on the original left chart (as I type "adding 2nd line), it automatically reflects in the left and right chart. (image 1)
But when the text is altered in the chart that it is copied to, the right chart (when I type "adding 3rd line"), it isn't changed on the chart, even though it looks like it is since it shows up as it is typed, but it doesn't show up on either chart. (image 2)
The other drawings allow for changing of the drawing regardless of if its from the original chart or that chart that its copied to. I assume this is a minor bug specifically with the text tool?
Date Time Of Last Edit: 2017-05-13 01:19:33
imagetest 1.jpg / V - Attached On 2017-05-13 01:06:43 UTC - Size: 175.48 KB - 339 views
imagetest 2.jpg / V - Attached On 2017-05-13 01:06:51 UTC - Size: 197.14 KB - 338 views
[2017-05-13 18:25:38]
Thank you for pointing this out. We will look into this and see what the issue is.
[2017-05-14 21:11:36]
This is corrected in 1557.
