Date/Time: Tue, 14 Jan 2025 11:31:52 +0000
sc.IsDateTimeInSession always return 1
View Count: 832
[2017-05-12 22:31:16] |
User612903 - Posts: 51 |
Hi, I'm trying to use this function that I found in the doc. I've set session time, for the test I even tried a session that start at 9.00 am and finish at 9.01am. But this : int IsInSession = sc.IsDateTimeInSession(sc.BaseDateTimeIn[sc.Index]); Always return 1. Should it not return 0/false when it's not in the se[/code]ssion time defined in the Chart Settings ? Thanks for your help, Regards |
[2017-05-13 00:42:45] |
This is always going to be true because the data loaded in the chart must be within the session times: int IsInSession = sc.IsDateTimeInSession(sc.BaseDateTimeIn[sc.Index]); Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-13 00:42:59
[2017-05-13 13:50:11] |
oh ok i got it. It's now working with "sc.CurrentSystemDateTime". But since I have 2 sierrachart on the same computer with 2 different timezone I'm stuck Is there a function to get the current time of the sierra chart ? Thanks for your help |
[2017-05-13 18:10:03] |
This is the current time in the Sierra Chart time zone: ACSIL Interface Members - Variables and Arrays: sc.CurrentSystemDateTime Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-13 18:13:05
