Date/Time: Tue, 14 Jan 2025 12:52:20 +0000
Chartbook not saving with SC1555/SC1556
View Count: 842
[2017-05-12 18:23:38] |
TechTrader - Posts: 116 |
After updating from SC1549 to SC1555/SC1556 this chartbook causes SC to hang when saving or attempting to exit the program. After a forced close and restarting SC, the chartbook is not in minimised state and has no formulas in it. There are other chartbooks with the same scss formulas files but only with 2 sheets which do not cause the problem. The chartbook is OK with SC1549
Date Time Of Last Edit: 2017-05-12 18:26:40
Private File Private File Private File |
[2017-05-12 18:41:00] |
We will test this. For the record, the study collection is not relevant. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-16 18:19:00] |
Jeffrey - Posts: 2194 |
Saving large spreadsheets should take less time in the next release. This should help prevent the program from freezing. There are a lot of unused cells with formulas in this spreadsheet. You may want to clear those cells to help improve performance. |
