Date/Time: Tue, 14 Jan 2025 09:59:12 +0000
CQG FIX Prices
View Count: 869
[2017-05-12 16:41:00]
User246418 - Posts: 3
Hi, my prices for NQ seem off today, also GC yesterday (on SIM) - is there a way I can check if problem with feed??
[2017-05-12 16:54:19]
You just have to compare with another data feed. You could use the Sierra Chart Exchange Data Feed:
[2017-05-12 17:07:21]
I am in a live trade room, so I know it's not correct. How do I resolve??
[2017-05-12 17:17:23]
I've restarted PC and appears to be ok now. Will keep an eye on it, and let you know if I have any other problems.
Thx
[2017-05-12 17:51:40]
There is no point in telling us about this particular data feed issue. We are not the provider of the data feed and are not likely able to help you.
It is best you contact your broker or use the Sierra Chart Exchange Data Feed instead.
