Date/Time: Tue, 14 Jan 2025 10:41:02 +0000
Minor Documentation error
View Count: 885
[2017-05-12 14:17:55]
User98657 - Posts: 329
I was searching for documentation on chartbook tabs and I found the "To Switch Between Chartbook Tabs" section. In that section it says to goto Global Setting?General Settings>General 2 and look under the Tabs frame.
It is not located under General 2, but rather General 1.
[2017-05-12 15:28:01]
Can you give us the link to the page that you found this text on?
[2017-05-12 15:30:43]
Chartbooks (Workspaces)
You need to scroll down a little to get to:
https://www.screencast.com/t/3LQLVwxaRDLy
[2017-05-12 16:46:09]
This has been corrected.
