Date/Time: Tue, 14 Jan 2025 11:26:47 +0000
[Programming Help] - ZigZag Study doesnt display length of zigzag line in spreadsheet
View Count: 1492
[2017-05-12 11:45:27] |
4646ed - Posts: 230 |
The ZigZag Study doesnt display length of zigzag line in spreadsheet, even with additional output for spreadsheets set to yes. How do I fix this? It shows them on the chart, though. But i need the data in a place that i can perform further calculations on it. Date Time Of Last Edit: 2017-05-12 11:46:55
[2017-05-12 20:11:32] |
This actually can be done in the latest version of Sierra Chart by referencing the Zig Zag Oscillator Subgraph.
[2017-05-13 06:31:36] |
Actually not the subgraph i needed -- but your answer pointed me towards the fact that i had zig zag line length and zig zag number of bars subgraphs set to ignore thus they weren't showing up in the spreadsheet. So. Next question: what information is the zig zag oscillator subgraph illustrating? And what are the extension lines?I found no explanations in the documentation. Date Time Of Last Edit: 2017-05-13 06:32:06
[2017-05-13 18:24:53] |
Both of these have now been documented or documented more fully documented. Refer to the updated documentation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-13 18:54:09] |
Refer to: Zig Zag: Displaying the Zig Zag Oscillator Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
