Date/Time: Tue, 14 Jan 2025 10:26:51 +0000
Calling Print Screen from ACSIL
View Count: 859
[2017-05-12 10:58:11] |
Pinger - Posts: 33 |
Hi I would like have my custom study save an image of it's chart automatically every 5 bars, say, with my order and position lines. Is there an ACSIL print screen/window function which I can use to achieve this? Or would I have to implement this through some Win32 programming? Kind regards |
[2017-05-12 18:39:42] |
This is supported. Use this variable: ACSIL Interface Members - Variables and Arrays: sc.SaveChartImageToFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
