Date/Time: Tue, 14 Jan 2025 11:49:32 +0000
number bars imbalance on top of background coloring
View Count: 1769
[2017-05-12 06:36:43] |
User884550 - Posts: 149 |
pls advise if possible to add diagonal text imbalance highlight to attached chart with askvol/bid vol perc background coloring, so that coloring of imbalances would be different from column1 range colors? if i just add text coloring as diagonal dominant side on attached chart, it uses same colors as background and distorts all the chart, as screnn#2 |
2017-05-12_09h24_00.png / V - Attached On 2017-05-12 06:36:36 UTC - Size: 7.31 KB - 382 views 2017-05-12_09h36_22.png / V - Attached On 2017-05-12 06:36:39 UTC - Size: 10.33 KB - 390 views |
[2017-05-12 08:26:27] |
fjgaspar - Posts: 62 |
I am afraid is not possible. And it would be nice to be able to do. If you choose any background coloring method, and any text coloring method for one column, both background and text use the same colors. So if you choose for example background coloring method on dominant diagonal size, and text coloring method dominant diagonal size, both will use the same colors, so you will end with no text in imbalances (background same color than text = no text at all). It would be useful to be able to choose separate colors for background and text. |
[2017-05-12 08:31:07] |
yes, and maybe be able to use larger font for imbalances as well Sierra, can this be smth you can include in future? |
[2017-05-13 00:43:21] |
We will see if we can work this in during the next week.
[2017-05-15 14:06:13] |
Version 1557 supports different text coloring compared with the background coloring for the Numbers Bars study. There are new Inputs for this in the Numbers Bars study.
