Date/Time: Tue, 14 Jan 2025 10:29:26 +0000
tick data question
View Count: 670
[2017-05-12 02:06:22] |
User103949 - Posts: 78 |
I have been real-time testing same strategies with ES-201706-GLOBEX and YM-201706-GLOBEX. I can always replicate the same signal triggered in real-time during replay afterwards for ES but sometimes the signal maybe missing or not able to be replicated for YM. I am wondering if the tick data in real time is consistent with the one i use for replay or downloaded later? Thanks, |
[2017-05-12 04:02:40] |
Yes it is consistent when using the Sierra Chart Exchange Data Feed.However, refer to: Auto Trade System Back Testing: Differences Between Back Testing and Real-Time Auto Trade System Evaluation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
