Date/Time: Tue, 14 Jan 2025 09:58:57 +0000
User Email
View Count: 1050
[2017-05-11 20:41:20] |
Sierra Chart - Max - Posts: 5778 |
Hi. Hope all is well.
I was considering purchasing your platform but wanted to double check that it supports the TTM squeeze indicator as utilised by options trader John F Carter and his team at Simpler Options. I found this link about the squeeze indicator and it provides an option to purchase it for the Sierra platform. However, the site looks dated. Wanted to check if Sierra still supports the TTM squeeze indicator. Here is the link: http://www.tradethemarkets.com/products/item5.cfm Look forward to your advice. Regards Sierra Chart Support |
[2017-05-12 03:55:47] |
Yes, Sierra Chart does support the TTM Squeeze indicator, but would be best to check with Trade The Markets first since they are the ones who developed that.
