Date/Time: Tue, 14 Jan 2025 10:43:05 +0000
Pls make it much more obvious that SC is in simulation mode
View Count: 729
[2017-05-11 14:56:59] |
pappe88 - Posts: 22 |
Hi there! I'm sitting here the whole week having no good signal. Now finally a signal which matches my plan! I enter, it goes well buuuut... I was on simulation. I'm currently really frustrated. It's was the first good signal and than wasted on Sim. Pls. make something that makes it way more obvious that SC is in Sim mode. The little colour change in the upper left is not enough. I would be fine with a background text. Or anything I see when watching the charts. Even an optional message box for simulation which tells me that I am doing this order on sim. |
[2017-05-11 21:47:31] |
Sawtooth - Posts: 4151 |
Go to Global Settings >> Graphics Settings-Global >> Colors and Widths tab >> scroll down to Chart Trade Window Background - Simulation Mode
[2017-05-12 03:51:24] |
The best way to do this is to change the background color of the Trade Window to an obvious color. Refer to: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM And refer to: Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-12 14:02:34] |
That helps a lot. Thank you very much!
