Date/Time: Tue, 14 Jan 2025 10:08:00 +0000
TPO Value Area Lines Study
View Count: 1351
[2017-05-11 14:43:04] |
User968625 - Posts: 260 |
Hello, Thanks for highlighting this study before. I am trying to see the PoC line as it travels through the day up/down as is is something that market profile followers do. I assumed I can get that by setting up the draw style as stair step but it is not working. to make sure I am clear. for example the POC after one hour is at 2385 but after three hours is at 2390. then I would see the POC on the first two hours at 2385 then I see it as a stair where the new value is drawen starting from the time it started migrating up. Can you please check why this is not working or what I need to do? |
[2017-05-11 15:00:34] |
Here is the documentation for the study: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=158#TPO_Value_Area_Lines You need to set the Draw Developing Value Area Lines input to Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
