Date/Time: Tue, 14 Jan 2025 10:43:53 +0000
[Programming Help] - Pivot Study
View Count: 722
[2017-05-11 12:06:16]
User352023 - Posts: 20
Hi, is it possible for the variable period study to have it draw a line to any bars in the until it touches that level?
thank you
[2017-05-11 14:31:49]
No, this is not supported but you could modify the study to meet your requirements.
Refer to:
https://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html
If you want us to refer you to a programmer, let us know.
[2017-05-11 14:44:32]
Many thanks for your reply.
In which file do I find the study please? Can you point me to what function I need to use to draw line until future intersection.
Thank you
[2017-05-12 04:08:40]
Refer to the following:
https://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html#SearchingSourceCodeBuiltIn
sc.AddLineUntilFutureIntersection()
