Date/Time: Tue, 14 Jan 2025 12:02:31 +0000
Numbers Bars Question
View Count: 1650
[2017-05-11 11:47:04]
infpz - Posts: 826
Is there anyway that when there are consecutive aggressive buyers or sellers (such as in the picture), that the chart can be set up where it will either automatically draw lines there or perhaps an extending rectangle like I drew there?
Noted, this chart is not on my computer which is I did not post it the traditional way. It is an image sent to me by someone else.
image123.png / V - Attached On 2017-05-11 11:46:03 UTC - Size: 41.6 KB - 405 views
[2017-05-12 04:31:11]
No, this is not supported but we do get asked about this from time to time. We have to see about it later on.
We are certain there are some third-party tools that do this though.
Check with this website:
http://www.emojitrading.com/
[2017-05-12 10:15:43]
infpz - Posts: 826
Lee's stuff is great - thanks. -PZ
[2017-05-13 17:18:48]
binaryduke - Posts: 373
https://www.emojitrading.com/stacked-imbalances/
is exactly what's being asked for here.
[2017-05-18 19:47:09]
gomifromparis - Posts: 244
You can also find an orderflow tool here : https://www.gomicators.com/gomorderflowpro
Screen caps are of NT8 but the same version runs on SierraChart.
Disclaimer : I'm the vendor.
[2017-05-18 19:48:52]
infpz - Posts: 826
Gomi, please contact me: pz@infinityfutures.com
[2017-05-19 06:39:29]
@sstfrederik - Posts: 405
I have created study that does this. If you want to try it out, let me know frederik@simplesystemtrading.com
