Date/Time: Tue, 04 Nov 2025 18:08:30 +0000
Chart Drawing Drag and Drop
View Count: 2663
[2013-04-03 10:03:29]
OtaTrader - Posts: 5
is it possible to drag a drawing and drop it into other chart? Or is there a way how to synchronize drawings? If I move a horizontal line from 100 to 102 on one chart the line automatically moves to 102 on the other chart?
Thank you
imagesc.png / V - Attached On 2013-04-03 10:02:54 UTC - Size: 81.81 KB - 983 views
[2013-04-03 17:21:33]
This is supported. Refer to this page:
http://www.sierrachart.com/index.php?l=doc/helpdetails72.html
