Date/Time: Wed, 15 Jan 2025 16:22:57 +0000
Can this please be fixed?
View Count: 1189
[2017-05-11 01:09:52] |
User839162 - Posts: 87 |
Please take a look at the Trade DOM Recenter Line in the attached image. It goes through the middle of the bids/ask/price. Can you please adjust this so it's between the bid/ask on the line... instead of in the middle? Thanks |
SierraChart_2017-05-10_20-03-58.png / V - Attached On 2017-05-11 01:06:24 UTC - Size: 193.17 KB - 412 views Attachment Deleted. |
[2017-05-11 05:00:06] |
We will look into this.
[2017-05-15 15:48:31] |
Any update on this? I'm assuming the re-centering would need adjusted so all DOM's line up with the line between the bid/ask. It currently doesn't re-center properly. It's important for me when watching the Treasuries to see if the others are up ticking/down ticking. Thanks |
[2017-05-17 04:25:57] |
Allow a few weeks for us to look into this.
[2017-05-31 04:03:37] |
Any idea how much longer before this is fixed? Or do you have any updates you can give me? Thanks! |
[2017-06-01 02:45:51] |
No. We do have this on our list. It is on our near-term list but that could still be weeks away. We are only doing our best.
[2017-06-28 22:56:04] |
We are going to concentrate on all of this and related items either late this week or next.
[2017-07-24 01:13:10] |
This has now been completed in the latest prerelease.
