Date/Time: Tue, 14 Jan 2025 09:59:28 +0000
Delay outputting data to file with Write bar data to file study
View Count: 1057
[2017-05-11 00:27:19]
Bitcoinadvisor - Posts: 14
I have a few charts that I am capturing price information to a data file, but the output on the chart is not always in the sync with output to the data file. There can be a delay writing to the file.
I have noticed this when I try and output chart data with an interval of 1hr, 4hrs and 8hrs. The only chart it seems to work ok is on a 1 minute chart.
What can I do to force sierra to output a completed bar soon as it in available?
thanks
Andrew
[2017-05-11 04:20:36]
This behavior is documented:
https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=182#Write_Bar_Data_to_File
The study does not do what you require but you could make some modifications to accomplish what you want. Refer to:
https://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html
