Date/Time: Sat, 18 Jan 2025 13:09:04 +0000
Extend Until Future Intersection
View Count: 1706
[2017-05-10 00:27:45] |
QnReally - Posts: 181 |
Recently you have added a few enhancements to support extending lines until a future intersection. It is a great feature in my opinion. I was wondering if you can support a tool like Horizontal Ray Tool to extend until a future intersection. You have also provided the ACSIL support for this feature. Using that API I can code it myself but I think it would be better if you weigh in on this because a native enhancement would come with a lot of other benefits that are baked into your tools system. Thanks. |
[2017-05-10 05:21:19] |
We do not see anything like this happening anytime soon. This is a major development task. It is far from simple. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-01-08 01:54:22] |
Is this enhancement a possibility in the near future? Thanks. |
[2018-01-16 23:17:27] |
We determined a relatively simple way to do this and it should be out next week.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-16 23:17:44
[2018-02-12 03:11:37] |
Thank you so much. This works great for Horizontal Ray. I was playing with an ACS study to see if I can detect a horizontal ray that extends into the future versus another one that intersects some chart bars. I tried s_UseTool.EndIndex and s_UseTool.EndDateTime properties but they both didn't work because by default, I guess, there is no end point for a Ray. Is there another property of s_UseTool I can use to detect if a Horizontal Ray intersects some bars, when it is set to Extent Until Future Intersection? |
[2018-02-12 04:41:04] |
No there is not.
[2018-02-13 12:07:00] |
Just curious. I suppose you would keep the state somewhere internally when the line is intersected to avoid repeated future calculations. Is it possible to expose that data via ACS please? Thanks.
[2018-02-15 19:16:53] |
No, that is not internally held. It is determined when it is drawn.
[2018-02-16 01:27:52] |
I was really hoping it was internally held. Here is why. I use it in an unorthodox way. I draw these horizontal rays on the screen when I see some important levels forming that I can see but it would be pretty hard to code that logic with ACS. Then I go through the chart with an ACS study and export the levels and text represented by those user drawn rays to a flat file. The intention is that, when a ray intersects a price candle bar in the future I would stop exporting that level. These exported levels are used for other purposes such as importing into another program I use for trading. Can you please explore any ideas you may have on how to make this intersection data available through ACS? Thank you so much. |
[2018-02-20 19:43:50] |
We will look into this.
[2018-02-20 23:09:35] |
In the next release you will use s_UseTool::FourthIndex to access this particular bar index where the horizontal touched and stopped.
