Date/Time: Mon, 13 Jan 2025 19:54:54 +0000
Weekly RTH charts/Volume/Data Window...
View Count: 1215
[2017-05-09 19:20:06] |
User629089 - Posts: 93 |
Hi, I'd like to set up weekly (and monthly) RTH charts. The only way to set up a weekly/monthly now that I'm seeing is through "historical" and not "intraday". Historical appears to default to ETH. Is there any way to get RTH only? Also, while setting up SC I ran across the ability to add volume to a chart. What I mean is the actual amount of volume for the day like from the QuoteBoard. I can't find now how to do this now. Can you help? Also, is there the ability to have a data window set up on a chart (in particular a Volume Profile/Market Profile chart or any chart for that matter) in addition to the Tool Values window? Thanks... |
[2017-05-09 20:04:29] |
Here are the instructions for RTH Weekly and Monthly bars: Chart Session Times: Day Session Only Weekly Chart Bars Chart Session Times: Day Session Only Monthly Chart Bars You can add the Daily Volume field to the Chart Header. Refer to: Working With Charts: Region Data Line / Chart Header For the "Data Window", refer to: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
