Date/Time: Mon, 13 Jan 2025 19:25:45 +0000
Euro 3 session chart problem
View Count: 965
[2017-05-09 19:09:27] |
User161390 - Posts: 16 |
I have had a 24 hour chart set up for Euro futures (E6 contract). I have a separate profile for Asia session (15:15-00:59:59), Europe session (01:00-06:59:59), and US Session (07:00-15:14:59). Recently the settings seem to be reverting to have the wrong session time set on the chart and this messes up the profiles. See the attached images. I can change the session back to 24 hrs with no evening session (15:15-15:14:59). After saving the settings, the chart loads once and looks correct for a second, and then reloads and looks wrong again (like the attached screenshot) and the session settings have reverted. Here is an upload of the messed up chart. Also notice one of the images I upload where I point out a profile artifact that looks like it should go with the latest profile for the last few bars (circled in red). http://www.sierrachart.com/image.php?Image=1494356888943.png |
EuroSessions-RevertsToThis.PNG / V - Attached On 2017-05-09 19:06:03 UTC - Size: 48.98 KB - 268 views EuroSessions-TryingToSetToThis.PNG / V - Attached On 2017-05-09 19:06:09 UTC - Size: 53.85 KB - 300 views EuroSessions.PNG / V - Attached On 2017-05-09 19:06:22 UTC - Size: 120.91 KB - 262 views ES-Day.cht - Attached On 2017-05-09 19:07:04 UTC - Size: 2.48 MB - 383 views |
[2017-05-09 19:50:40] |
It is clear what the problem is. The chart is being referenced by other charts. Refer to: Chart Session Times: Session Times Automatically Changing Unexpectedly Also notice one of the images I upload where I point out a profile artifact that looks like it should go with the latest profile for the last few bars (circled in red).
Let us know if you still need help with this.
