Date/Time: Tue, 14 Jan 2025 10:03:42 +0000
SC level 3, level 5 and an idea for the trading dom.
View Count: 1173
[2017-05-09 18:47:06] |
User375110 - Posts: 28 |
SC: 1. Do I understand correctly that level 3 includes the Sierra Trading Dom and also it includes the study called TPO value area lines? 2. However, if the full TPO chart is needed with the letters, and etc., then level 5 would be needed. Is that correct? 3. I have an idea to make your Trading Dom even better than it is right now. If a trader could detach a trading dom, like he / she can detach a chart, that would really be great. That way each dom could be placed directly below or above the corresponding chart when it is minimized. Any chance that you will be making this update soon? FWIW, I think your charts are the best. They are very stable; and, they seem to be able to do almost anything a trader would like them too. Date Time Of Last Edit: 2017-05-09 18:48:33
[2017-05-09 19:53:54] |
1. Yes. 2. Yes. 3. This is already supported, we will prepare an example for you. Thank you for the comment. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-10 15:50:32] |
SC: Did you ever get an example for question #3 above, prepared? |
[2017-05-12 03:45:19] |
Yes. It is attached. Here are the instructions to use it: Chartbooks (Workspaces): Using a Chartbook Provided by Sierra Chart Support Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
TradingDOMExample.cht - Attached On 2017-05-12 03:44:29 UTC - Size: 21.15 KB - 421 views |
