Date/Time: Tue, 14 Jan 2025 09:58:07 +0000
How share Chart data between Instances?
View Count: 1170
[2017-05-09 17:40:44]
User791263 - Posts: 151
(I logged in via Help per your instructions to repost; Also added $ to my SC Direct account)
How can 2 instances share chart data built from 2 different feeds?
Can 2 instances assist each other with heavy analysis from different timing, markets, bars sizes and data storage time unit (1 second vs tick)?
This would overcome computer limits I have reached.
Your purpose of instances seems to be:
1) Allow specialization of market data server, or
2) Allow trading from different accounts (or both simultaneously).
Example: I need one instance to use tick-by-tick for inside-bar studies and different time frames/ start times (by TCP/IP asynchronous communication of instances?).
The other instance does heavy 51 charts+10 spreadsheets processing with 1-second data storage.
Such 51 charts-instance can't handle tick-by-tick processing (I think). The computer is at limit.
The ability to use different start times, time frames (bar length) and numbers bars could give a cross-check. Different start time of charting gives different (useful) results.
Cross-market analysis is also useful.
If chart or spreadsheet data sharing worked, I would eventually use about 3 instances this way.
(The Space Shuttle used this approach- 2 different hardwares, 4 computers cross-checking).
This might be by:
a) an Overlay Study from other instance, or
b) sharing a single spreadsheet with 2 sheets accessing each other (Sheet would be instance#-Chart# ?), or
c) one instance use a new "data server" mode to send chart-study results to overlay on a target instance chart (like packet headers with instance#-chart#-study# prefix).
I'm guessing you all thought about dividing computer labor-resources for heavy demands, since you worked to utilize threads.
[2017-05-10 23:08:24]
This is definitely supported just by using another instance and using the DTC Server. This is fully documented on this page here:
Using DTC Server for Data and Trading in Another Sierra Chart Instance
Each instance can use a different Intraday Data Storage Time Unit:
https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#IntradayStorageUnit
There is no ability to share study data. Only the historical and real-time market data.
Date Time Of Last Edit: 2017-05-10 23:09:21
