Date/Time: Tue, 14 Jan 2025 11:50:37 +0000
number bars @1554
View Count: 1015
[2017-05-09 16:10:08] |
User132748 - Posts: 159 |
There is a problem with number bars after last update. Pls check Ask/Bid Split Profile with Dominant Side. It draws all equal size bars. Thanks
[2017-05-09 16:28:01] |
We have already fixed this. We will put a new revision out in about 20 minutes.
[2017-05-09 16:50:52] |
We have put out the new revision. Update to the "Prerelease" by following these instructions: http://www.sierrachart.com/index.php?page=doc/SoftwareDownload.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-09 18:07:55] |
User167259 - Posts: 9 |
Also running 1554. Background type of Volume Profile not displaying.
[2017-05-09 20:10:19] |
Could you please update again with Help >> Download Prerelease and let us know if you still see this issue: Background type of Volume Profile not displaying.
The version number will be the same. It is just a new revision. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-09 20:32:35] |
Running the prerelease version. Volume profile will not display when background coloring method is set to dominant or diagonal dominant side. Other options seem to work.
[2017-05-10 06:04:41] |
This has been resolved in version 1555.
[2017-05-11 13:00:38] |
User20450 - Posts: 330 |
also the range 0 up down color is missing from 1554 and up , used to be on charts now its gone
2017-05-11_08-57.jpg / V - Attached On 2017-05-11 13:00:09 UTC - Size: 268.59 KB - 290 views Attachment Deleted. |
[2017-05-11 13:37:07] |
OK we think we know what you mean. We need some time to work through this. The recent changes were intended to make the Numbers Bars study function more proper with setting combinations which inherently do not make sense and end up raising unnecessary support issues. It is not until we get the feedback do we then see what users are actually doing and expecting. It is challenging, because what someone considers wrong, someone considers acceptable. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-12 00:40:22] |
sure no problem , let me know if i can be of any help as i have been trading orderflow for yrs , thanks guys
[2017-05-15 15:05:26] |
Update to the latest prerelease.
