Date/Time: Tue, 14 Jan 2025 12:30:40 +0000
Strange large volume indicator colour
View Count: 1018
[2017-05-09 07:06:06] |
User19165 - Posts: 346 |
Looking at this indicator on the euro bund is showing an odd colouring. This indicator should be set to only paint a yellow or blue, yet I get this weird grey every so often. I've never noticed this on the DAX, but it is occurring quite regularly on the Bund - any idea what is happening here?
GBL_large_volume_ind.png / V - Attached On 2017-05-09 07:05:59 UTC - Size: 14.87 KB - 285 views |
[2017-05-10 02:34:55] |
You may be thinking well its because you have transparent style selected and it is two markers sitting on top of each other. Here is another screenshot showing with transparent style set to "No". Same problem.
Date Time Of Last Edit: 2017-05-10 02:35:14
MK-2017-05-10_143144.png / V - Attached On 2017-05-10 02:35:09 UTC - Size: 34.56 KB - 267 views |
[2017-05-10 02:37:12] |
Just updated to your latest stable build 1554 and now the transparent setting doesn't work at all?
MK-2017-05-10_143624.png / V - Attached On 2017-05-10 02:37:07 UTC - Size: 77.67 KB - 273 views |
[2017-05-10 06:17:48] |
The transparency setting now exists on the Subgraphs tab of the Study Settings window and is specific for individual studies. Update to version 1555 and it will be properly set. Regarding the original problem, post the chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-10 06:33:47] |
OK, I'll update tomorrow outside of market hours. Rolled back to my last known stable of 1549. Chartbook attached. |
Private File |
[2017-05-11 03:07:53] |
Some extra information noticed last night, every time the odd coloured marker appeared, the size was either 75 or 74. My size filter is set to 74 in this indicator. I also note that for showing a 74 or 75 lot trade, the marker is not only unusually coloured, but also too big. Something weird going on here, no idea why I'm getting this behaviour on Bund and not DAX.
Date Time Of Last Edit: 2017-05-11 10:10:12
[2017-05-12 01:06:54] |
Updated to version 1555, still a problem with these dot sizes and colouring on the Bund.
[2017-05-12 01:29:34] |
We have not looked at this. We probably will not get to it until next week.
[2017-05-17 00:02:51] |
This problem has been identified and resolved. A new release will be out later today.
