Date/Time: Mon, 13 Jan 2025 19:51:43 +0000
Chart Settings Issue
View Count: 692
[2017-05-08 21:42:58] |
User612786 - Posts: 2 |
Hi Please have a look at the attached image of my Chart Settings. There is an issue with the Session Times settings. This is on all my charts. I have installed the latest version and rebooted etc etc. Thanks Cliff Copestake |
Sierra Settings.png / V - Attached On 2017-05-08 21:40:59 UTC - Size: 36.88 KB - 260 views Attachment Deleted. |
[2017-05-08 22:30:56] |
This is due to a problem with the latest update of Windows 10. It is a Windows issue. You have to rollback the prior update of Windows 10. Or maybe they have another update that fixes this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
