Date/Time: Mon, 13 Jan 2025 19:20:56 +0000
I cant open SC,getting this message,i installed this link and still cant open SC,need help
View Count: 633
[2017-05-08 19:15:36]
User909489 - Posts: 1
Windows Error Message: Missing MSVCP120.dll File
When launching a Native Instruments application on a Windows system, you may get the following error message regarding a missing "MSVCP120.dll" file: The program can't start because MSVCP120.dll is missing from your computer. Try reinstalling the program to fix this problem.
In case you receive this error message regarding a missing DLL file, you have to install the Microsoft Visual Studio 2013 Runtime Libraries. Download them here: Visual C++ Redistributable Packages for Visual Studio 2013
[2017-05-09 03:52:03]
We apologize for the delay. We are looking into this now.
[2017-05-09 04:38:39]
We want you to install Sierra Chart again using the installer:
https://www.sierrachart.com/downloads/SierraChartFileDownloader.exe
You definitely should not encounter that error message. After installing Sierra Chart again let us know if you have any further problems.
If so, we can help you with remote assistance.
