Date/Time: Mon, 13 Jan 2025 19:28:12 +0000
Crossair showing on multiple charts at the same time
View Count: 673
[2017-05-08 14:40:14] |
Fabio - Posts: 117 |
Good morning all, I am quite new to using SC and I am setting it up right now. I have this kind of trouble with the crosair. I am using different monitors showing different markets, but when I go through one chart, the crossair pointer is showing on the other charts as well creating me a bit of noise.. There is some option in order to avoid this problem and get the crossair just on the chart where I am focus on? Thanks for the kind reply. Fabio. |
[2017-05-08 16:54:40] |
Yes. You need to disable Tools >> Global Cursor On: http://www.sierrachart.com/index.php?page=doc/Tools.html#GlobalCursor Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
