Date/Time: Mon, 13 Jan 2025 19:40:24 +0000
DOM - volume by price study
View Count: 1108
[2017-05-08 11:43:32] |
dominikos - Posts: 106 |
Is it possible with a volume by price study to show all trades completed in the last 15 minutes? I have it currently configured 'one period at end of fixed time' and time period length set to 15 minutes. But I don't see a smooth transition which leads me to believe that this time is just reset every 15 minutes. How can I configure it to show me the last 15 minutes and smoothly move forward? |
[2017-05-08 12:12:38] |
The configuration is correct but also select Chart >> Chart Settings and set the Days-Minutes-Seconds setting to 0-0-30.
[2017-05-08 12:14:18] |
Thank you, I had it setup to volume per bar.
