Date/Time: Mon, 13 Jan 2025 19:55:26 +0000
delay of the spreadsheet study
View Count: 688
[2017-05-08 10:43:23]
user - Posts: 78
hi there,
I am using your platform to catch some real-time futures data, however I find there is around 15sec delay for the spreadsheet to display the new line, may you please support, thanks!!
[2017-05-08 12:07:25]
This is not clear for us.
How do you come to this conclusion?
[2017-05-09 02:22:39]
user - Posts: 78
ok, now I test again, it's around 5-10sec delay. let me clarify.
I am using 5min data, with aided by the built-in spreadsheet function.
As you know there is a clock right on top of the title bar, normally if there is no delay, right at the moment 10:05:00, 11:45:00 (for example), it will display a new line.
However it does not go in this way.
Please kindly support.
[2017-05-09 02:59:21]
What actually you are referring to is a new chart bar and it does not make sense that it immediately occurs at the beginning of the chart bar timeframe. Refer to:
https://www.sierrachart.com/index.php?page=doc/helpdetails4.html#h4.10
