Date/Time: Mon, 13 Jan 2025 19:30:39 +0000
NYMEX Brent Crude Financial Futures (QA) doesn't update with SC Historical data
View Count: 625
[2017-05-08 10:24:00] |
User626121 - Posts: 82 |
Hi, I just compared SC Realtime Exchange data for NYMEX Brent (I use it with IB, so symbol is BZ) with SC Historical data for Brent (Symbol: QA) and saw that for all contract months except September (U) there is no intraday data after March 15th with SC Historical data feed. SC Realtime data is fine. Could you please fix this. Thx. Date Time Of Last Edit: 2017-05-08 10:24:48
[2017-05-09 03:47:22] |
We are not seeing this problem. Follow the instructions here to re-download the data: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
