Date/Time: Mon, 13 Jan 2025 19:37:29 +0000
Click and drag drawing tools
View Count: 1748
[2017-05-08 10:04:56] |
grantx - Posts: 244 |
I want to single click a tool, hold the left mouse button, move the tool (eg horizontal line), let go of the left mouse button and the tool has been moved and pointer is back at hand tool. Possible? Date Time Of Last Edit: 2017-05-08 10:05:30
[2017-05-09 07:44:28] |
This is supported. These are the following two options in Global Settings >> Tool Settings to support this: Support Drag For Chart Drawing Creation/Modification: Require Drag to Start Drawing Modification: They are documented here: Chart Drawing Tools: General Tool Settings Although the documentation needs some updating and we will do that later today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-09 14:07:08
[2017-05-10 05:12:59] |
The documentation has been updated now.
