Date/Time: Mon, 13 Jan 2025 19:17:26 +0000
save variable on hdd
View Count: 622
[2017-05-07 20:57:53] |
maxpi - Posts: 181 |
I thought I read about this subject some time in the past but can't find anything with various search terms... Does the Sierra Chart environment provide a facility to save a variable on the hdd between sessions? Maybe that is more in the purview of C++ coding and in which case, does the environment provide a facility to perform C++ functions on shutdown? |
[2017-05-08 04:40:58] |
Refer to: ACSIL Interface Members - Variables and Arrays: sc.StorageBlock Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
