Date/Time: Thu, 23 Jan 2025 14:39:03 +0000
Volume Profile Colouring
View Count: 893
[2017-05-07 00:35:32]
Rexz - Posts: 22
Hi, I noticed the volume bars come with Bid Volume and Ask Volume colouring which allows me to set a difference or delta to show Bid/Ask difference on each volume bar which is great. The only problem I have is it doesn't show any Bid/Ask volume colouring on top of the Value area, only outside it. Is there a way to have it display on the value area? http://www.sierrachart.com/image.php?Image=149411727017.png
Thanks Sam
[2017-05-07 04:24:47]
The best that can be done is to set this Input to Yes:
https://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_HighlightValueAreaHighAndLowOnly
[2017-05-08 14:53:42]
Rexz - Posts: 22
That is one way of doing it but not really a solution. Would it be possible this could be mentioned for a future update fix? I don't see why you couldn't colour the value area and then apply the delta on top.
[2018-11-30 10:02:07]
User829216 - Posts: 15
+1
