Date/Time: Mon, 13 Jan 2025 19:30:12 +0000
Commodities charts
View Count: 721
[2017-05-06 21:07:48] |
User92899 - Posts: 76 |
Hi - I've had a query from a user about the times that the EOD commodities charts we are using update. We are using the following charts: HG*: Copper SL*: Silver ZL*: Soybean Oil CL*: Crude Oil CC*: Cocoa GC*: Gold Is there a set time when these charts update - and allow our study to calculate any potential signal? - as the user claims it's "a bit random" - personally I've not tried to see when an EOD chart updates, but I'm trying to answer this question. Thanks, Colin - Project X / ACTS |
[2017-05-07 04:13:13] |
There is not a set time. They will update at least once a day. It can seem random. The best procedure is around 17:30 US Eastern time, select this command to bring the charts up to date: Edit >> Download Data for All Historical Charts. If you need them to automatically update at a set time, we need to look into how to implement that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-07 04:13:57
