Date/Time: Mon, 13 Jan 2025 19:57:37 +0000
Color bar based on alert condition - RSI
View Count: 2171
[2017-05-06 18:13:40] |
trumpy - Posts: 37 |
Hi - I'm pretty new to Sierra trying to figure out how to set the color bar based on alert condition based on RSI line value. INPUTS: RSI Line = ID3.SG1 What I'm looking for is on a range bar chart whenever a bar closes AND the RSI Line value is within a range of 45 to 55 then color the bar. I have tried a few iterations based on example but not quite getting it to work right any help appreciated. Thanks |
[2017-05-07 18:06:38] |
This is what I am trying to get to work but it is throwing an error as I'm sure my syntax is wrong; ID3.SG1<55,AND ID3.SG1>45 Thanks |
[2017-05-07 18:17:48] |
On the Color Bar Based on Alert Condition study, enter this Alert Formula: AND(ID3.SG1<=55,ID3.SG1>=45) Also enable the Evaluate on Bar Close option. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-07 23:33:33] |
Excellent thanks that worked.
