Date/Time: Mon, 13 Jan 2025 19:37:50 +0000
2charts in one chartbook
View Count: 792
[2017-05-06 16:26:43] |
User177821 - Posts: 3 |
Hi, please help. I have a problem with SC data. I have 2 charts open, for NQM17, in one chartbook First chart 1min, second chart 5min. At the same time, I have a different price. I attach screen scanning. How do I set the data to be the same price at the same time? |
chart_the same time.jpg / V - Attached On 2017-05-06 16:26:28 UTC - Size: 245.27 KB - 259 views |
[2017-05-06 16:51:06] |
Do you know that those two charts are not sscrolled to the very end displaying the last bar? If you understand that, then you are asking for a total and complete impossibility. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-06 17:00:30] |
I'm sorry, but I do not understand. If I trade a 5min graph, I will have a price at 15:30 5646,75 and if I trade a 1min chart, will I have a price of 5646,25? Should not the price be the same? |
[2017-05-06 17:21:53] |
No, because the time of 15:30 is the starting time of the chart bar: Chart Session Times: Bar Starting Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
