Date/Time: Mon, 13 Jan 2025 20:00:16 +0000
[User Discussion] - Displacing subgraph values (not only visually)
View Count: 745
[2017-05-06 10:02:10] |
User352023 - Posts: 20 |
Hi, I have managed to display subgraph values from the displacement setting on the subgraph tab however, the values of the displaced subgraph would still be the same if I export the data. Is there a way to shift the actual values and bind it to the new bar (not just visually on the chart). Thank you |
[2017-05-06 15:18:12] |
Sawtooth - Posts: 4151 |
The data moves to the new bar when viewed in a spreadsheet study, but the export function ignores the displacement. Here's a workaround: Add the Spreadsheet Study study -Highlight a range of cells -Press Ctrl-C to copy -Paste into Excel -Edit as needed -Save As a .txt file |
[2017-05-07 05:50:59] |
Hi tom, thanks a lot for your reply. Don't you think this is a bug and should be fixed? The whole idea of having an export is not to mess around with manual copying and pasting. This is what I need to avoid since I can't do it manually as it would take ages. Do you think there is a workaround that I could displace value and having them displaced in a write bar and study data to file automatically? Thanks |
[2017-05-07 05:59:48] |
Maybe this could be done with ACSIL.
[2017-05-07 06:03:46] |
Thanks for your reply Tom. I hope Sierra can give their input. |
[2017-05-07 13:06:34] |
Here's another more direct way: Put this in K3: =AA3 AA3 would be the displaced study, but when you export, column K retains the displacement. |
[2017-05-07 14:36:26] |
thanks tom. This works around the issue of the export.
