Date/Time: Mon, 13 Jan 2025 19:28:54 +0000
Numbers Bars Question
View Count: 814
[2017-05-05 20:08:47]
infpz - Posts: 826
My question pertains to the Numbers Bars study only. Currently, i have the study setup to show me diagonal BID x ASK imbalance of 400% and 800%, this is working correctly. What i am seeking to achieve, is to filter out the imbalance signals that trigger correctly, but are at low volume and therefore of no interest. For example, 50 Bid X 250 ASK will signal on my chart, and this is of interest. However 5 Bid VS 1 Ask will also signal, but is of not interest to me. Therefore, i would like to filter these imbalance signals with a minimum number of contracts traded diagonally. Is this possible?
[2017-05-06 20:21:46]
We can add support for a new diagonal comparison background/text coloring method which uses actual values and not percentages. This is the only thing we can do.
[2017-05-08 04:37:07]
Actually, we realize the particular Numbers Bars study Input setting you need to accomplish what you want is this one:
Numbers Bars: Bid/Ask Minimum Volume Compare Threshold
We will still see about adding the new coloring method though.
Date Time Of Last Edit: 2017-05-08 04:37:25
