Date/Time: Mon, 13 Jan 2025 19:15:57 +0000
VbP with shaded bid/ask difference
View Count: 686
[2017-05-05 17:47:07] |
User740709 - Posts: 153 |
Hello, I am sorry to bother you with this, I am unable to find it in the description of the Volume by Price study. Is it please possible to have a VolumebyPrice study shaded based on the percentage of bid/ask difference? I mean like the third image here: https://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Examples The description below the image says that it is a combination of VbP and numbers bars but I can replicate this only with numbers bars and I cant see an option to do it with VbP. Thanks a lot. Best regards, Hana |
[2017-05-05 17:52:34] |
No, this is not supported but there is this method of color coding: http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_ColorCodeVolumeBarsBasedOnPercentageOfPOC Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-05 18:06:00] |
Thanks for a fast response. Best regards, Hana Date Time Of Last Edit: 2017-05-05 18:58:02
