Date/Time: Mon, 13 Jan 2025 19:27:59 +0000
User Question
View Count: 746
[2017-05-05 17:05:46] |
Sierra Chart - Max - Posts: 5778 |
I payed $3.25 for Nasdaq indicies. When I trayied open chart NASDAQ 100 indicie that chart was blank and there where not datas on the background. What I payied in the sum $3.25? Sierra Chart Support |
[2017-05-05 17:50:03] |
Tell us the symbol you are using for the NASDAQ 100. It should be: $IUXX If you still do not receive historical or real-time data, then follow through the instructions here to update the Symbol Settings: http://www.sierrachart.com/index.php?page=doc/GlobalSymbolSettings.php#UpdateSettingsSteps Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
