Date/Time: Mon, 13 Jan 2025 19:44:43 +0000
Expand SS Request
View Count: 704
[2017-05-05 14:29:26]
User98657 - Posts: 329
It would be great if in one of your upcoming improvements you could add a spreadsheet column for us to use with/ahead of column H. It would be good to have a column ahead of H where we could write descriptions of values contained/formulated in H.
[2017-05-05 15:46:35]
You can use any other available two columns in the Spreadsheet. You will need to use ones towards the right after the columns used for studies.
[2017-05-05 18:07:28]
Sawtooth - Posts: 4151
That would work, but they would be overwritten if you added any new studies.
[2017-05-05 18:58:28]
Additionally the far-right columns are not exactly user friendly with respect to the important data columns we need to work with on the left.
I would want this new column to be static, just another "H" type column.
