Date/Time: Sat, 12 Sep 2026 21:23:40 +0000
Historical chart
View Count: 1340
| [2013-08-22 15:17:27] |
| User39772 - Posts: 311 |
I use IQfeed an my chart settings. This is the daily chart I see http://www.sierrachart.com/image.php?l=1377184453332.png DaysToDisplay: 300, Intraday Chart 1-0-0. When I switch to Historical Chart this will not be accepted by SC an switched back to Intraday Chart. What do I have to do do see 300 days in a daily chart with daily candles ? |
| [2013-08-23 04:45:58] |
We see no problem switching between a Historical and a Intraday chart. What version of Sierra Chart are you running? We recommend updating to the latest Sierra Chart version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-04-09 14:21:55] |
It is version 1235. It is a bit strange. When the market opened the premarket daily disappeared and the candle startet again with the opening. But before the market opened there was already a daily candle visible with premarket data. Try to check it a few minutes before opening with a symbol like FB.
| [2015-04-09 16:52:02] |
This may make sense. This would be because the daily high and low from the data/trading service you are using does not provide the pre-market data. Refer to the documentation here: Historical Chart Prices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-04-09 16:52:28
