Date/Time: Wed, 09 Sep 2026 12:27:57 +0000
MoveToBreakEven ACSIL
View Count: 2470
| [2017-05-05 10:57:09] |
| User571607 - Posts: 4 |
Hi, How to set "Move to Breakeven for Stop" for Step 1 and step 2, if i use : NewOrder.MoveToBreakEven.Type=MOVETO_BE_ACTION_TYPE_NEGATIVE_OFFSET_TRIGGERED; NewOrder.MoveToBreakEven.TriggerOffsetInTicks= 4; NewOrder.MoveToBreakEven.BreakEvenLevelOffsetInTicks= -6; it only set "Step 1", and i can not find any example how to fill "Step 2" Date Time Of Last Edit: 2017-05-05 11:00:08
| [2017-05-05 16:57:13] |
There is no support for Move to Breakeven for Stops >> Step 2 from ACSIL.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-05 16:57:44
| [2017-05-05 18:43:17] |
Is any posibility that in the future it will be supported?
| [2017-05-08 18:32:04] |
Yes but we do not know when.
| [2020-10-14 08:12:56] |
| User164131 - Posts: 19 |
Hello guys, Do you have any news about support Step2 for BreakEven from ACSIL? |
| [2020-10-14 11:45:03] |
Yes we will get this implemented this week.
| [2020-10-19 14:27:19] |
Hi, I updated to v2183 and according to this info (https://www.sierrachart.com/index.php?page=doc/Whats_New.php&p=1#SCVer2183) you "Added the s_SCNewOrder::MoveToBreakEven_2 member to the ACSIL new order structure to set the settings for Step 2 for Move to Breakeven for Stops" In the file "scstructures.h" I see: struct s_MoveToBreakEven { int Type = MOVETO_BE_ACTION_TYPE_NONE; int BreakEvenLevelOffsetInTicks = 0; int TriggerOffsetInTicks = 0; int TriggerOCOGroup = 0; }; s_MoveToBreakEven MoveToBreakEven; //Version 18 s_MoveToBreakEven MoveToBreakEven_2; How exactly we can use it in our code? In tradingsystem.cpp example for BE_step_1 was: NewOrder.MoveToBreakEven.Type = MOVETO_BE_ACTION_TYPE_OFFSET_TRIGGERED; NewOrder.MoveToBreakEven.TriggerOffsetInTicks = 5; NewOrder.MoveToBreakEven.BreakEvenLevelOffsetInTicks = 0; |
| [2020-10-20 08:51:49] |
You would use it like this: NewOrder.MoveToBreakEven_2.Type = MOVETO_BE_ACTION_TYPE_OFFSET_TRIGGERED;
NewOrder.MoveToBreakEven_2.TriggerOffsetInTicks = 5; NewOrder.MoveToBreakEven_2.BreakEvenLevelOffsetInTicks = 0; Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
