Date/Time: Mon, 13 Jan 2025 19:23:26 +0000
IB, CQG, Sierra
View Count: 1156
[2017-05-05 10:32:02] |
grantx - Posts: 244 |
IB with CQG on Sierra? What is your opinion of this configuration? Better to use IB data? Im just trying to figure out a stable setup with little hassles going forward. Also, will I be able to run a single instance of Sierra with CQG as data and IB as brokers? Date Time Of Last Edit: 2017-05-05 11:38:08
[2017-05-05 16:44:03] |
It will be best to use Interactive Brokers with the Sierra Chart Exchange Data Feed: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php Also, will I be able to run a single instance of Sierra with CQG as data and IB as brokers? No this is not supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-05 16:44:48
[2017-05-05 19:05:55] |
Just so that I am clear: I have to pay: 35 USD/month for a real time data connection (Im not clear what this is for). 15.75 USD/month for Full CME nonprofessional Trading Group 33 USD/Month for Sierra package 5 Total = 83.75 USD/Month all in? |
[2017-05-05 19:33:47] |
Yes, this is correct.
[2017-05-09 17:02:18] |
Does sierra charts work OK with Dorman?
[2017-05-09 17:19:39] |
The general answer is yes, but will you be using CQG, Rithmic or CTS with them? All of these are documented here: https://www.sierrachart.com/index.php?page=doc/Data.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-09 19:40:54] |
Ill be using CQG data with them, what do you think? Im just looking for a no hassle setup here. Before I sign up with you guys, broker and data provider, I want to make sure I have the best combination. I want to trade not troubleshoot issues. Or what about stage 5 with CQG? I just received an email from them with rates etc.. |
[2017-05-09 20:14:59] |
CQG will be just fine. You can also use the Sierra Chart Exchange Data Feed with CQG: Sierra Chart Exchange Data Feed You potentially could have issues with the initial set up but that would be on the broker side with the CQG account configuration. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
